Originally posted by KSAV8TOR
Also..they give you thick spring steel rod and they are impossible to z bend..they will break before you get it right,so i used regular "silver" pushod on the servo ends.
Other than that the Airplane is a nice one!
Im assuming you mean the z bend is hard to make on the servo end. I would suggest using a connector like this one:
http://www2.towerhobbies.com/cgi-bin...?&I=LXD930&P=7
there are many similar to this that you can try according to your needs. These are the ones I use and are handy when needing to make small adjustments
