RCU Forums - View Single Post - Airplane Finish
Old 02-15-2010 | 07:51 PM
  #32
ram3500-RCU's Avatar
ram3500-RCU
My Feedback: (221)
Default RE: Airplane Finish
ORIGINAL: dhal22
ORIGINAL: flyncajun
It`s not possible to finish with glass and paint as light or lighter than film covering ,just cant be done with a quality outcome.
However, if the build is properly planed you can get a light finish only,By building lighter and taking advantage of the glass strength
you can achieve maybe 40 grams increase on wings and 100 grams on the fuse over film.There is about a 10 0z difference on a pattern size plane total ,glass paint/vs plastic film.
You have to remember it takes Years of mastery to properly plan, and build for durability , quality ,with a light airframe outcome to make it possible.
Just putting the glass on a wing is the same weight as film,now you have primer,panit and possibly clear.
Using Dope, Tissue ,silk span ect. is light, might be doable by the pro`s like Matt k. and maybe Dean Pappas, but it`s not very durable, you have to also be a master at taking care of it as well.Then, You have to be very carfull to make a season without the need for a refurbish.
If your not trying to meet a weight goal use Mike`s technique it`s good!. but if you are trying to save weight,, you won`t.
Bryan
monocote is 1.75 - 2.25 oz per sq yd i think. glass can be bought as light as .50 oz per sq yd.
yea, but your not done with glass. You have resin, then a second coat of resin (usually), then primer, then color and as noted, maybe clear. Then, you pull your hair out if you have to repair it.
