RCU Forums - View Single Post - Strange Symptom (Backdraft 8e)
Old 02-15-2010 | 08:17 PM
Chizzler
Default RE: Strange Symptom (Backdraft 8e)
On the reverse issue, it's almost like it's not getting a signal. I've got the ESCprogrammed Ithink for 40% break when letting off the trigger. When it comes to a complete stop, I can push the trigger forward several times and nothing happens. But, if I reverse the switch on the transmitter so pulling the trigger is reverse and pushing it forward is forward, reverse works fine...That's got me stumped.
On the other issue, Idid not check the center diff. The pinion set screw looked good, wheel fastners looked good, drive axles looked good and hubs were fine. The batteries are charging now. I'll run it until it happens again and maybe throw a quick video up on here so you guys can see / hear what it's doing. I'll need to check the center diff also. For some reason, I was struggling getting that apart. Any quick tips for getting that apart?
