RCU Forums - View Single Post - cable to carb???
Old 02-16-2010 | 03:18 PM
carrellh's Avatar
carrellh
Default RE: cable to carb???
ORIGINAL: chevyv8
Also another ? I have a confirmed good battery. When I flip the switch on, the servos twitch. When I try the controller, I get nothin. What should I check?
Is the transsmitter and receiver you are working with the same as the ones in the thread?
http://www.rcuniverse.com/forum/fb.asp?m=9505333
If yes, and if you have not gotten the correct crystals, it is not going to work.
