 cable to carb??? >
cable to carb???
cable to carb???
Old 02-16-2010 | 10:45 AM
MinnFlyer's Avatar
Default RE: cable to carb???
True, if you were that worried about it, you could grind or file the area clean and add some JB-Weld for piece of mind.
Old 02-16-2010 | 11:15 AM
GaryHarris's Avatar
And being a 4 stroke where crankcase pressure isnt an issue, just JB weld it!
Old 02-16-2010 | 02:08 PM
That's not a crack, or a molding flaw (crease).
It's a small revine awaiting JB Weld (Slow cure) for peace-of-mind.
Old 02-16-2010 | 02:26 PM
MinnFlyer's Avatar
I agree. A crack would not have such rounded edges.
Old 02-16-2010 | 03:18 PM
carrellh's Avatar
ORIGINAL: chevyv8
Also another ? I have a confirmed good battery. When I flip the switch on, the servos twitch. When I try the controller, I get nothin. What should I check?
Is the transsmitter and receiver you are working with the same as the ones in the thread?
http://www.rcuniverse.com/forum/fb.asp?m=9505333
If yes, and if you have not gotten the correct crystals, it is not going to work.
Old 02-16-2010 | 03:53 PM
  #31
If you have a TX that can be operated in eitherPCMor PPMmode, make sue the mode is set correctly for your RX. I cost me near $40 because I didn't check and sent the RX in for repair. The reciver and servos will act as you describe if the mode is wrong.
Don
ORIGINAL: chevyv8
I will take closer look. I just a quick look with a pick. It didn't catch, but I will clean it and set some oil in the area and see if oil seeps through. I looked on tower for the arm but all I see is the carb.
Old 02-17-2010 | 11:20 AM
  #32
Hi!
Many newbies just bolt their engines down on a plastic mount without checking the mounting lugs for trueness (so that they are level).
Othervise the crank case can get bent and crack
Old 02-17-2010 | 12:28 PM
  #33
Cant recall in over 50 plus years of messing with motors that I ever saw a mount on a motor that was not stright and level - Guess I missed a few over time but never had a crscked case eather from mounting- That was starting at the time of McCoy red heads and brown jrs , and Hornets up to present day motors
Nope the Skydivers dont have motors
Don
