RE: Dragon Lady firewall spacer required?
The plans call for offsetting the vertical thrust line and having the horizontal thrust line 3 3/4 inches measured from the bottom. Did you use these measurements or did you position the vertical thrust line center of the fuse and the horizontal thrust line center of the fuel tank outlet?
