RCU Forums - View Single Post - four servos & split ailerons?
Old 02-17-2010 | 02:55 PM
Jonathan Ott
My Feedback: (25)
Default RE: four servos & split ailerons?
I'm going to cut the aileron into two seperate control surfaces at the center control horn and then simply re-cover the cut ends. Then, I'll install servos as if it were a standard four servo arrangement. I'll utilize the programming guide (attached below) to program the radio for a quad servo wing, ala the Ultra Stick 60.
The unfortunate thing with my Giles is my ailerons are already attached and hinged, but this is a small inconvenienvce for me, now I just have to be extra careful cutting the ailerons in half.
Fortunately, the hinges are such that there is a hinge on either side of the proposed cut, so the ends will be supported!
The programming seems a little intense, but should be fun in the end.
Jon
File Type: pdf
