RCU Forums - View Single Post - My HE Leopard 2A5 modification to HL
Old 02-18-2010 | 11:08 AM
beachboy
Default RE: My HE Leopard 2A5 modification to HL
Done some testing to day about the turret movements:
1. Tested all 3 transmitters/sender I've got against the working M26 -> Everything is working fine, including the turret movement.
2. Did a test wiring with a different receiverboard hooked up to the RX18, battery and turret motor. Hooked the turret motor to pin 1 and 2 at CN9 connector. -> No movements of the turret motor. Testet towards the Left and Right engine and I get the turret motor moving.
3. Have also tested 2 different RX18, and they both give the same result as for the turret motor. No movements of the motor.
Now I don't know what to check or do next.
Meassuring the voltage at pin 1 and 2 of the CN9, I get 4.6V without any load. Connecting the turret motor, the voltage drops to 0V. Moving the transmitterstick for turret movement, I don't see any change in the voltage at pin 1 and 2.
I have also testet with 3 different 7.2V battery packages (that I know works fine in the M26).
I dont understand why I cannot make the turret move...?
Beachboy
ID:	1381661   Click image for larger version
