RE: electrical help neened
From Saxon's post, use the 8 pin turret connector diagram ("CN9" on the RX18 diagram itself). Wire color as you mentioned doesn't matter, as the function is determined by pin, you only need to figure out which is "pin 1" and you are good to go from there.
At least as I understand your problem.
