RCU Forums - View Single Post - How do I balance this thing?
Thread
02-18-2010 | 08:00 PM
15
Popriv
May 2008
828
bellingham, MA
RE: How do I balance this thing?
I try to do something each night to keep things moving... I'm hoping to maiden it this weekend. should be in the 40s, a heat wave!
Here is a shot from above it it tells you anything?
alot of firsts in this build...couldnt do it without all your help.
wing half:
root is 8.5" tip is 5.25" length is 29.5" plus 1.5" ailerons using a clark Y airfoil.
This is a little smaller than I had estimated in earlier posts. Someone had indicated that was a little small for a .15 engine???
Fuselage length:
from the prop to the LE is 8"
wing is 8.5"
From TE to elevator hingeline is 9"
Stll a few loose ends but almost there.
Reply
Like
Popriv
View Public Profile
Send a private message to Popriv
Find More Posts by Popriv
View iTrader Profile
