RCU Forums - View Single Post - Help for making a plug from foam
Old 02-21-2010 | 12:19 PM
mun_iz
Default RE: Help for making a plug from foam
One of the putty that i am testing (the darker grey one) in the pic above is from a brand called Dynatron.. I noted that the maker of this putty is Bondo Corporation... Is this Bondo?
I had used this putty before and had noted that even after prolonged drying, it does not dry to a hard texture... it remains slightly flexible and elastic (sort of rubbery...). It does sand smooth but it fouls up the sand paper very quickly. When sanded dry, it creates a lot of fibrous particles (fromed from the sanding debris).
If this is Bondo, please kindly advise on working with this putty.
