RCU Forums - View Single Post - O.S 91 four stroke starting problems
Old 02-22-2010 | 08:22 AM
psuguru
Default RE: O.S 91 four stroke starting problems
ORIGINAL: Gray Beard
A few drops of lighter fluid and the new plug is a big help. Even here when it gets into the 30s or high 20s mine are harder to start. That's when I quit using my clip on glow driver and go to my power panel with the juice turned up. I have a few of the .91s and for some reason they are very cold blooded?? Sometimes when it goes into the 20s {high 20s} I roll the engine over with my starter and have someone put there finger over the muffler hole too, sort of a close and open thing until it starts. I leave the driver on the plug and run my engine up to about 4000rpm for about a half minute or so then it's good to go.
My OS 91 needs to be wet enough to be making squelching noises on hand-flick before it will start. With a type F plug and in inverted installation, I use 2.3Amp at the plug and it starts with a hand flick. More current than that and it pre-ignites and kicks back. Less than 2A and it won't fire at all.
10% nitro, 18% ML70 synthetic.
