I appreciate RC Airport Staff's candid review of the Hangar 9 Alpha Trainer.
Hangar 9 Alpha Trainer - RTF Those I spoke with at the field knew little about the new package. The article played a major part in my decision to purchase the Alpha over several other RTF's (thanks for bringing to light the engine displacement…lol).
I have a few questions regarding the proper reinforcement of the tail with triangular balsa stock. I understand the concept and welcome any suggestions.
1) Since the model comes covered, I assume that I need to remove small pieces of the covering on the vert. and hor. stabilizers with a blade to ensure a good bond when gluing? Is this correct, or is there another way to do this?
2) Should I taper the leading and trailing edges of the balsa stock to ensure smooth air flow across the tail, or is the balsa stock small enough to cause only a minor change given the large control surfaces.
3) So that it doesn't look like I just slapped 4 pieces of balsa on the tail, do I seal and paint the balsa stock, or is there a better way to do this?
Thank you.
