RCU Forums - View Single Post - Hangar 9 Alpha Trainer - Reinforcing the Tail
Old 11-26-2002 | 07:59 AM
blueangel
Default Hangar 9 Alpha Trainer - Reinforcing the Tail
AirBear is right. If you don't remve the covering then you won't get a good bond to the wood. The triangle stock could rip off in flight. You don't have to taper the leading and trailing edges. It will make it look better though. You should cover all visible wood with monocote for looks and for fuelproofing.
