RCU Forums - View Single Post - Hitec Spectra 2.4 module upgrade
Old 02-24-2010 | 12:19 AM
MikeMayberry's Avatar
MikeMayberry
Default RE: Hitec Spectra 2.4 module upgrade
Yes, the Hitec Spectra 2.4Ghz module is compatible with any Futaba radio that uses the same size module. Also be aware that we offer the standard module (wired antenna that replaces the standard antenna in the same mounting location) with (2) 7Ch RX's for $129.99. However, the "Promo" module will be better if you plan to switch back and forth between 2.4Ghz and 72Mhz because the antenna is hard mounted onto the back of the module. But I guess if you send in your only 72Mhz module you won't be doing that now, will you?!?!?
Mike.
