RCU Forums - View Single Post - So, you can’t see the lights?
Old 02-24-2010 | 10:55 PM
N429EM's Avatar
N429EM
Default RE: So, you can’t see the lights?
The cable ends are flush with the fuse, and, again, I used a couple drops of canopy glue to keep the cables in place.
Even in the brightly lit meeting room, the club members in the back of the room could still see the lighted cable end. Up close, outside, there’s no problem seeing the light. Now, after checking for any abnormal lights, I can safely turn off the switch, knowing all was well on that flight.
Remember: You are making changes to a piece of equipment that is not sanctioned by the manufacturer, and will probably void the warranty. Attempting this operation, is at your own risk. I cannot be responsible for your ability to complete the operation safely.
However, if you do try it, let us know how yours goes. Mine works fine.
Good luck,
EJ
