RE: Prop nut
It's 5mm, the same as the OS .15LA, so anything that says it will fit the OS LA will fit.
I'm not sure about the pitch, but I think it's 1mm.
At least some of the Magnum manual on the older XL was wrong, and said 6mm, when that engine is also the same as the others, 5mm
