Prop nut
It's 5mm, the same as the OS .15LA, so anything that says it will fit the OS LA will fit.
I'm not sure about the pitch, but I think it's 1mm.
At least some of the Magnum manual on the older XL was wrong, and said 6mm, when that engine is also the same as the others, 5mm
Yes, it is M5 with the standard pitch of 0.8mm. Very common size, the AP 09 and 15 have this too for instance.
(For M6 the standard pitch is 1mm as hinted at above)
