RCU Forums - View Single Post - overheating esc?
Old 02-26-2010 | 12:55 PM
timcat26
Default RE: overheating esc?
ORIGINAL: cm5299
ORIGINAL: timcat26
Make sure that your throttle control is not reversed on the radio you're using. You can check this by putting the stick to the full throttle position and then plugging in the battery (make sure the plane is secured first!) and see if you hear the arming beeps.
This one little thing cost me a newesc, motor andbatterysetup to learn about when I was relatively new to RC planes.
Also make sure if you have throw limits enabled on your TX, you undo them. I reversed channels about 300 times before figuring that one out.
A very good point.
