RCU Forums - View Single Post - motor / ESC timing
Old 02-26-2010 | 10:11 PM
lbarnes
Default motor / ESC timing
Need some advise on timing, I think....
I have a brushless motor that the specs tell me should draw 20A and produce 200W. This motor is installed on a HK 250, with a 40A ESC. during testing I have placed my Watt's up meter and found something else.
Under 1/2 throttle is am drawing 56A, and developing 540w, and the motor and ESC is HOT!
The spec's on the motor are:
Turgeny E500, 6T, 4000Kv, with 11 tooth pinion
I have checked all rotos for binding and have found NO defects in the Heli.
The ESC is set up for the following:
break off
Li PO battery
cut off mode - cut/off
start mode - super soft
timing - high
Anyone got any suggestions?
Would timing issues cause over heating and high current draw?
Larry
