ORIGINAL: Meller
Ohhh man...
The speaker came loose, and I think it came in contact with the Power + - on the amp... No more sound
I noticed that the RX18 is getting very hot, around the SW and SM, when I plug in the amp - It wasn´t that hot before... If the amp
is broken, could that make the RX18 unit hot aound SW and SM (Very hot)?
Thanks for the help guys
- Meller
P.s - Just ordered a new amp
Yep amp was loud drawing to much power from the spot you hooked it up to.
You need to hook the amps + & - to the power directly to the power lead on the on and off switch on the tank and the other wire from the amp directly to the wire from the battery plug wire.
Also like i said before the amps with the volume control are best because you will have your HL amp turned down really low like you are hardly using it from the tanks board so it will stay cooler also.... then you turn up the amps volume and this way it will also sound clearer with less distortion...... this is coming from a Guy who always had high end home audio components.
