RCU Forums - View Single Post - 3W MONO AMPLIFIER
Old 03-04-2010 | 03:29 PM
shenlonco's Avatar
shenlonco
Default RE: 3W MONO AMPLIFIER
ORIGINAL: Meller
Thanks for the help Shenlonco
*Edit* - This is the way you want me to hook it up, right?
Hi yes but make sure the power wires to the amp one goes on the on and off switch so when you shut off the tank the amps power shuts off also.. Another thing is you want to put the HL speakers wires directly into the AMPS input with the tanks VOLUME almost off so you can set the amps volume at like 1/2 way up and then adjust the tanks volume to gain the sound you like . you may be able to go 3/4 up on the amps volume that's kind of rule of thumb on amps they say no more than 3/4 after that they start distorting.
