RE: Bipe aileron setup?!
Great thread, but I have a question: If the ailerons are connected at the trailing edge (or just aft), will the throw be the same for the upper and lower? I'm thinking that what matters is that each aileron is connected at the same location relative to each aileron, so whether it is above, below, or in the middle (at the TE), it should work fine as long as both ailerons are done the same way.
thanks
Steve
