The Module Pins, Should I be concearned?
Hi AnnMarie,
First let me say your time spent here is a true asset to RCU and I thank you for taking the time to help us!
My question relates to the problems the 8U had regarding the pins that slide into the frequency module. It was well known that you had to remove the rear cover and resolder the pins on the 8U since they would break the solder joints at the board. I know a few people who lost planes because of this problem, unaware of this issue with the radio. My question is, Sould I be concearned about the same problem with the 9C? Do I need to regularly check the pins? I dont change my module often but do use seperate modules for shop work and flying. Thanks again...
Todd Witkoff
