RE: Capacitors
hey joe
i solder an extra cap to my esc,i solder it as close to the originalcaps as i can, i put a biy of hot glue between them, cut 5mm of tube of the the batt leads, twist the pins on the caps around the wires and solder them on, once done, a piece of heat shrink around everything and yoyr done
better response, cooler running and the esc lives longer
