RE: CMPro Lancair
I have recently completed this plane and notice that the right elevator control surface is a bit warped and the two elevator control surfaces do not line up perfectly. The right elevator lines up fine on the furthest right point but as you pan back towards the ruddr you can see it is warped and has a slight decline in the wood. Will this be a major issue or will trimming work it out?
