RCU Forums - View Single Post - Alcohol to thin epoxy
Old 04-04-2002 | 11:16 PM
TOYMAKER
Default Alcohol to thin epoxy
Originally posted by Rodney
Don't bother to thin it, just put on as thin a coat as you can then gently heat it with your heat gun. It gets very thin and is absorbed into the wood much better. The heat will also speed up the cure. Just don't overdo the heat, don't get it so hot that it bubbles. If you need the strength of epoxy, I recommend that you do not thin it with anything other than the manufactures recommended thinners or you may suffer unwanted complications.
RODNEY....Right on... one other drawback to thinning epoxy is that it will shrink over time. Especialy if you mix it with micro baloons and thinner(alcohol). If you are using epoxy over c.f. or fiberglass you would be suprised how fast it wicks into the material with a little heat.
