RCU Forums - View Single Post - 4*60 build question
Old 03-09-2010 | 12:09 PM
Campgems
Default RE: 4*60 build question
Frenchie, Isee you use my faviorite landing gear also. That is the best gear for a 40 to 120 sized plane. Lots of spring, but more important total spring back. I've found that you can use the 60 size U-Can-Do wheel pants and you trim the pad on the gear to fit the notch on the pants. Use the same axel to hold the pants on the LG. Depending on the stance of the model, you may need to cut the pad a bit on an angle for grown clearance on the end of the pants.
Dduncanjlee, When you start your build, make sure you have readthe manual first, not just scan it, but really read it. And NEVER build ahead of the step you are doing.There are a couple places that if you dogetswep up in the build and do what you think is logical, itmay bite you. The sheeting of the wingcenter isone such place. When I started the sheeting, I finished it. Then I couldn'taccess the spar to get epoxy into the slot for the dihedral brace. Do just what the step calls for and nothing more. The instructions are very well writen. Best I've see for that matter.
Don
