Y Harness as a Lead Extension?
Hello!
I recently finished rebuilding a Tiger 60, but modified the original to have the elevator and rudder servos mounted in the tail. This requires two servo extensions, but I have none on hand.
Being impatiant, is it possible to hook up a Y harness in place of the lead, using just two of the three plugs?I understand it will reverse the servo on one side, but will it cause interference, battery drain, etc?
Thank you
Graeme
