RE: SR HELP AGAIN!?
The tail motor on the SR is very noise. Did you check all the motor and motor mount bolts? Did you check the gear mesh which is hard to do with a bad main gear. If the main blades struck the tail boom could case it. There is more then one thing that could cause a main gear to strip. Yes I had a main gear strip but it was do to a blade strike.
