E-Flite Helicopters Discuss the line of E-Flite mini and micro helis including the Blade CP, CP Pro, Blade CX, etc
SR HELP AGAIN!?
Old 03-14-2010 | 03:11 PM
Default SR HELP AGAIN!?
HI helli pros i dont know what happen with my sr im flyin is perfect out and then it makes a wierd sound in the air like gear striping is my second time flyin this bird an when i look at it the main gear is mising a few too.. i never crash it yet or anythink close to it .. i just would like to know if this happen toanybody an why? i dint get to use my other two batteries this realy sockkss im in other country in south america for vacation and nobody on lhs have this parts so im goin to place an order to helidirec and overnight this if anyone wants to tell me what other parts are recomended to get will be nice maybe some upgrades aluminun anwhere to get them ...ohh somethinkwhen i started to flyin i feel adelate in the rotor dont know if it wasme or is normal ...any help is good thankkss </p>
Old 03-14-2010 | 09:35 PM
46u's Avatar
46u
Default RE: SR HELP AGAIN!?
ORIGINAL: k20man
HI helli pros i dont know what happen with my sr im flyin is perfect out and then it makes a wierd sound in the air like gear striping is my second time flyin this bird an when i look at it the main gear is mising a few too.. i never crash it yet or anythink close to it .. i just would like to know if this happen to anybody an why? i dint get to use my other two batteries this realy sockkss [img][/img] im in other country in south america for vacation and nobody on lhs have this parts so im goin to place an order to helidirec and overnight this if anyone wants to tell me what other parts are recomended to get will be nice maybe some upgrades aluminun an where to get them ... ohh somethink when i started to flyin i feel a delate in the rotor dont know if it was me or is normal ... any help is good thankkss </p>
I am sorry but having trouble reading your post as many of the words are misspelled I do not know what they are like (delate).
Old 03-14-2010 | 09:51 PM
Stripping the main gear typically requires sudden stop of the blades. I have a CP Pro 2, MSR, MCX from E-Flite and a couple of HK450. I have only stripped the main gear a couple of times on the CP Pro 2, and a few times on the HK 450s due to either crash of blade impact. Main shaft (if it's like the CP Pro 2, the main gear comes with shaft) and spindle are also good things to have.
Old 03-14-2010 | 10:03 PM
46u's Avatar
46u
All so improper gear mesh can mess up a main gear or loose motor mount or motor bolts.
Old 03-14-2010 | 10:19 PM
46u thanks for try to understand my bad spelling!!
Old 03-14-2010 | 10:30 PM
46u's Avatar
46u
I would not up grade to anything aluminum till you are a really good flier. Aluminum many times can cause more breakage. On one of your other questions if I understand what your are asking check this link out. My spelling and English is poor but I try.
http://www.rcuniverse.com/forum/m_9577572/tm.htm
Old 03-14-2010 | 10:33 PM
yes I stripped the main gear why? I never crash or anything like it is my 2nd time flying this heli and in the air was makin weird noise. !!!!  anybody have this problem? thanks </p>
Old 03-14-2010 | 10:36 PM
46u's Avatar
46u
The tail motor on the SR is very noise. Did you check all the motor and motor mount bolts? Did you check the gear mesh which is hard to do with a bad main gear. If the main blades struck the tail boom could case it. There is more then one thing that could cause a main gear to strip. Yes I had a main gear strip but it was do to a blade strike.
Old 03-14-2010 | 10:41 PM
46u's Avatar
46u
I all ways keep a few extra main gears on hand with a few other extra parts. I have over 40 RC vehicles and I keep spares for all of them. I have as much or more in spare parts then I do my RC vehicles. [X(]
Old 03-14-2010 | 10:43 PM
yes I just did everything seen fine I check for the motor mounts is fine the main gear is missing few too, the blades are fine..
Old 03-14-2010 | 10:50 PM
yes i do the same with all my rc toys but because this heli is so new when i got it, it was no parts for it at that moment, and still hard to get parts for the only thing the i got extra is two more batteries
Old 03-14-2010 | 10:51 PM
46u's Avatar
46u
Gear mesh? Look on the tail boom and see if you see where the main blades hit it.
Old 03-14-2010 | 11:02 PM
not is fine all blue... when i get the main gear sure i replace the main shaft too? in my aling 450 trex when this happen i do it just in case!!  46u thanks for your help
Old 03-14-2010 | 11:24 PM
46u's Avatar
46u
If the main shaft is not bent it will be OK. I did not replace mine when I replace the gear but I checked it.
Old 03-14-2010 | 11:51 PM
any upgrade baterie for the sr?</p>
Old 03-15-2010 | 12:55 AM
Translate for you.
(oh, I think when I started to fly, I felt a delay in the tail rotor. I don't know if it is me, or if this is normal)<br type="_moz" />
Old 03-15-2010 | 01:04 AM
cool thanks solman .....
Old 03-15-2010 | 02:08 AM
No prob, I am here for you.
