RE: Air retracts systems
Ok Now I am having a small problem I have the retract system installed and ready to use.
But now I cant seem to get enough pressure in the tank. I am using a small compressor it is set to max at 100psi. My air retract system uses a one way valve for filling the tank and I cant seem to get enough pressure in it if I put the gear down while filling the tank it works and also for fear up. What am I doing wrong I installed the system as instructed no leaks any where and no blocks .
help!!!!!!!!!!
Thank you.
