ORIGINAL: jetsprintbasher976
can't find start up mode on istructions just cells3, cutoff , timing ,and running mode witch is just forward only and forward and back ! will timing reduce heat in my outrunner because the 35a almost burnt it up on 3s
Outrunner motors usually need 15* and more of timing to run good..
and if your setup is not right, that could be your heat issue
