Go Back  RCU Forums > RC Boats > Speed - Electric
 small seaking 35a problem! some help please >
Speed - Electric For all your electric boating needs.
Old 03-17-2010 | 10:34 PM
My Feedback: (-1)
Default small seaking 35a problem! some help please
seaking 35 amp watercooled version 2 brushless esc
just got one for my tearinto jet boat and low throttle is horrible . i have no low end controll it goes from zero to five mph as light as i can pull the trigger. other than that i soaked the hell out of it and still going strong
Old 03-18-2010 | 02:14 AM
Default RE: small seaking 35a problem! some help please
could try adjusting the start up, it lets you decide how you want the motor to start when you throttle up, this can be done through the transmitter or better is to buy a program card, hobbywing/seaking do the the same one. you can change the values of the esc and set it up how you want
Old 03-18-2010 | 02:44 AM
My Feedback: (20)
I agree a soft start up on the esc could help, also the correct timing on the esc to can help
Old 03-18-2010 | 02:57 AM
if you get a program card, leave the brake off, this will end up blowing your esc, all i have adjusted on my esc's are, voltage cut off (3.4v instead of 3.2v) start up ( from normal to soft) and motor timing (high timing for my outrunner motor)
Old 03-18-2010 | 10:07 AM
My Feedback: (-1)
can't find start up mode on istructions just cells3, cutoff , timing ,and running mode witch is just forward only and forward and back ! will timing reduce heat in my outrunner because the 35a almost burnt it up on 3s
Old 03-18-2010 | 11:09 AM
My Feedback: (20)
ORIGINAL: jetsprintbasher976
Outrunner motors usually need 15* and more of timing to run good..
and if your setup is not right, that could be your heat issue
Old 03-18-2010 | 05:32 PM
BACKEMF's Avatar
Turnigy Marine 35A Brushless Boat ESC
With an ultra fast CPU and USA power FETs, the Marine brushless esc is a high performance ESC capable of standard and competition use.
Programmable settings;
Reverse
Low Voltage (none/2.6v/2.8v/3v/3.2v/3.4v)
Brake: (none/soft/hard)
Timing (0.00/3.75/7.50/11.25/15.00/18.75/22.50/26.25)
Constant Current: 35A
Burst Current: 190A
Resistance: .0015 ohm
Battery: 2-3S Lipoly
BEC: 6v/ 1.5A
Motor Type: Sensorless Brushless
Size: 31.5 x 27.5 x 16mm
Weight: 32g
Old 03-19-2010 | 02:49 AM
I love these esc's, soaked them and they are fine. Yea I don't remember there being a startup setting. The low speed is going to be an issue with brushless but it sounds like you have something else going on.
Old 03-19-2010 | 02:52 AM
My Feedback: (20)
even at low speeds it should be very smooth through the system
i'd check every connection, a small tug and if any move slightly, take of the heat shrink and see if re-soldering is needed
Old 03-19-2010 | 02:54 AM
My Feedback: (20)
ORIGINAL: nick 30
good call nick!
Old 03-19-2010 | 02:59 AM
well srt, its happened to me, just one loose bullet on a batt and it was messing everything up
Old 03-19-2010 | 08:52 AM
My Feedback: (-1)
but my bro's does it to. before these esc i had low end control now i don't
Old 10-30-2010 | 12:31 AM
I know this post is old, but I am having this exact issue...I have tested two new Seaking 35 amp units and same issue. The program does not allow for throttle curve settings and despite any changes in the transmitter, I have almost no throttle curve at all. I am using this transmitter and receiver...
http://www.himodel.com/radios/2.4Ghz..._Set_N-4Q.html
Old 10-30-2010 | 07:25 PM
My Feedback: (20)
ORIGINAL: nick 30
Oh man, I thought I blew my UL-1 esc on the second run, only to find out one of the bullet connectors on the motor was loose
Old 07-16-2013 | 05:41 PM
Wow - I know, old thread but I'm so glad I finally found someone else to confirm this high start issue. I've had 2 of these POS' sitting in a box and always wondered if I was doing something wrong. I tried every adjustment/setting many times and nothing helped. If you do a bench test you can see that the 1st throttle step is like 20 to 30%. It was a problem just putting my little mono in my pool and flat out unusable in my rescue boat. And both were advertised as Ver 2...
I finally swapped both out with the HobbyWing/Turnigy Car 35 ESC's. What a difference having full low speed control!!!. Just be careful since they're not water resistant.
