HOOOOOOOOOOOOOOOOOOORAY!!!!!!!!!!!!!!!! I got the shaft out, Andy!!!!!!!!!!!!!!!! (Confetti)
. The problem was the set screw at the rotor hub was stripped, and so I used a reverse drill bit to get it out, then the shaft slid out perfectly. So then i rolled it down my granite counter tops, and saw that it was bent ever so slightly. So now if you could, I will send you my contact info, and I need to get a new main shaft. Also, I would like to get a new main gear, as I just want to make sure that it is not that either. Also, please order me some more set screws b/c I want to replace all of them on my heli b/c some of them were closed to being stripped, maybe 5 new set screws (please make sure they are the right size)
Can I order all this directly from you, or do I need to go through Nitroplanes (uuuuugh).
Thanks for the help again, Andy!!!!!!!!!!!!!!!!!!!!!!!! Wahoooooooooooooooooooooooo!!!!!!!!!!!!
