RCU Forums - View Single Post - small seaking 35a problem! some help please
Old 03-18-2010 | 05:32 PM
BACKEMF's Avatar
BACKEMF
Default RE: small seaking 35a problem! some help please
ORIGINAL: jetsprintbasher976
can't find start up mode on istructions just cells3, cutoff , timing ,and running mode witch is just forward only and forward and back ! will timing reduce heat in my outrunner because the 35a almost burnt it up on 3s
Turnigy Marine 35A Brushless Boat ESC
With an ultra fast CPU and USA power FETs, the Marine brushless esc is a high performance ESC capable of standard and competition use.
Programmable settings;
Reverse
Low Voltage (none/2.6v/2.8v/3v/3.2v/3.4v)
Brake: (none/soft/hard)
Timing (0.00/3.75/7.50/11.25/15.00/18.75/22.50/26.25)
Constant Current: 35A
Burst Current: 190A
Resistance: .0015 ohm
Battery: 2-3S Lipoly
BEC: 6v/ 1.5A
Motor Type: Sensorless Brushless
Size: 31.5 x 27.5 x 16mm
Weight: 32g
