RE: Nitro Planes EZ Trainer
Rog,
When you put your engine in, did you use the supplied mounts? Or did you use another type?
I am uncertain if the supplied mount is going to position the engine correctly. It looks as if it will center properly...but the vertical position seems wrong. Also and again...the manual isnt much help as it shows the engine to appear to be mounted on TOP of the mount rails, the diagram shows it mounted below the rails.
If I place the engine on top of the rails...it appears to be too high above the fuel tank. If I mount it below the fuse will have to have quite a bit of material removed in order for the exhaust to clear.
See my attached pics and any input is appreciated.
