RCU Forums - View Single Post - Diff fluid wt?
Old 03-19-2010 | 01:42 PM
K_B's Avatar
K_B
Default RE: Diff fluid wt?
What diff oil to use depends on the track and personal handling preferences. Just start with whatever the manual says to use and go from there.
Here's the Xray Setup Book for Buggies/Truggies. It should tell you what the effects of using different weight oils along with everything else.
http://www.teamxray.com/teamxray/sho...p?file_id=4461
