RE: ys 63 help!!!!!
sounds like you are currently using the newer version since you can not see how it comes apart. the top and bottom are press fit together. you will see a seam in the middle splitting top from bottom. you have to squeze a knife blade in the seam and then gently separate them. sometimes holes in the diaphram are too small to really see well and you replace them anyways as long as you got it open
