RCU Forums - View Single Post - Vertigo II Build Thread
Old 03-20-2010 | 02:01 AM
  #121
ponda
Default RE: Vertigo II Build Thread
OK..Hi..Just read the entire thread.....I have a plane from Sky Glas..Madison Hobby.....I bought it in 2008..huge original box....The fuse looks very similar..but has difference...hope someone can tell me what I have..I think It may be a Phoenix.....The fuse is white gelcoat..smooth but needs a little attention where the 2 halves were joined..no problem....it looks different on the tail....where I see in your pics what look to be pushrod exit housings,,2 of them...my fuse has none!..the rear of the fuse has a rounded opening as a jet exhaust exit on a real plane with the rudder ending above this..also the elevator assembly has to have an appropriate hole cut into the fuse for its fit. the wings and tail are white foam covered with a beige plastic type covering....it is not monocote or any similar product..it is a sheet plastic/vinyl ..looks like it came that way....There are no instructions.so I am paying attention to your build thread.
there is a wooden motor mount that is installed..would rather have a Dubro or similar....am somewhat clueless about the front wheel hook up...
anyway...if anyone has any info on just what this plane is....It looks like the Vertigo.but as I said..there are differences....
ok...hoping to hear from you guys....
thx...joe
