RC10GT .15 Stalling problems
sounds like you can't get enough fuel to the engine at full speed. maybe the problem is solved if you make the fuel line a bit longer. also, is the exit of the tank faced to the front or the rear? it should face the rear, because when you drive the fuel wants to go to the back of the tank, thus leaving (with 1/2 tank or so) none or little fuel in the front.
hope this helps you out.
