RCU Forums - View Single Post - gap filler with CA
Old 03-22-2010 | 03:44 PM
Campgems
Default RE: gap filler with CA
Thanks for the replys. Wouldn't you know it, I just vacuumed up the sawdust on my bench yesterday. I guess it wouldn't take long to manufacture another bit though. Ithink I'm going to see if I can get my finger into the wing and glue some 1/16" balsa backs under the crack, then just fill the crack with balsa putty. A closer inspection showed that only the last bay at the tip, had the crack running away from the LEstock. That is where the backing will be needed.
Don
