RE: gap filler with CA
Use Duco cement. It is sandable and shrinks when it cures. This will render the crack imperceptable because it will pull the crack closed. CA on an outer surface is a no- no unless you don't give a rat's butt what the airplane finish looks like! CA won't sand at an equal rate to its surround so the end result is a bunch of high and low spots.
