RE: Help with Simulated Metal
I think i am going to try glassing the nose like you suggested Tubig.
However, I have the Koverall on the fuse and a coat of Nitrate. Can i apply the glass and resin directly over this?
Or do i need to cut back the Koverall off the area i am going to be glassing and perhaps sand abit of the wood to remove any nitrate??
Also for the tape i lay down to stop the glass from contacting area i dont want, will regular green scotch painters tape work?
Thank you
