RCU Forums - View Single Post - Flap setup for newbies!
Old 03-23-2010 | 10:51 AM
abufletcher's Avatar
abufletcher
Default RE: Flap setup for newbies!
Next question: Since the instruction manual for my Black Horse Chipmonk 60 ARF doesn't give any recommended throws for the flaps, what's a good (and "conservative") "full" setting?
I still don't quite get how to use the CTR and EPA to set the positions. I would assume I just set ZERO (using push-rod adjustments and I guess also CTR) on the "no flaps" position on the switch and then set a "full flaps" on the 3rd position using the EPA. The 2nd position would just fall where it falls (presumably somewhere around 50% flap).
BTW, I do know enough about flaps to know NOT to use them at all until I'm used to how the model flies. And that it's a bad thing to deploy full flaps at full speed.
OK. I THINK I GOT IT. Everything seems to be functioning now (just needs fine tuning).
