RCU Forums - View Single Post - Vertigo II Build Thread
Old 03-23-2010 | 10:17 PM
  #134
KLXMASTER14's Avatar
KLXMASTER14
Default RE: Vertigo II Build Thread
ORIGINAL: crankpin
Robert - Good work. I have had a lot of gel coat fuselage's, and still have some, never thought of taking it off.
Vince
Vince,
The gel coat is just dead weight. It is useful for leveling the surfaces if you are diligent with a sanding block. The block is key (a valuable lesson from Bob Smith). You can hand-sand the gel coat away, but you will lose the benefit of leveling the low spots. You will end up with a wavy surface. You need that hard surface of the block to bridge the gaps.
I have a "before" weight, and I will borrow the work scale again to get an "after" weight. I am curious to see just how much weight that I have removed from the fuselage. It definitely feels lighter, but I want a number to back that up.
-Robert
