RE: Continued Battery Life Problems
Yes you need an in-line amp meter or watt meter, check total system draw in between the battery and receiver, and then you can check current draw of individual servos.
Also a voltmeter that you can plug into the system would be handy, to see at what voltage your failsafe system kicks in at.
