RE: An elevator splitter ?
Yes I will try to dig up the actual pictures that I took. I will also try to explane it again .Dubro makes really nice carbon fiber rods . One of the ones they make has two holes in one end for a Y application to the elevators . The opposite end has one hold for one push rod to the servo .
It will show you to add the two medal push rods into the end with two holes . You then add the Jbweld or expoxy to secure them all in place . You add a single rod in the end to the servo.
The end with a Y appearance (two pushrods coming out of one connection ) this end splips out the holes in the rear of the fuse , then you connect the ends of the Y pushrod to ecah elevator horn (and adjust them to even )
You connect the single end inside the fuse to the servo like any other pushrod
