RCU Forums - View Single Post - Airfoil explanation
Old 03-27-2010 | 06:06 PM
  #50
HighPlains
Default RE: Airfoil explanation
Most flat bottom airfoils will create lift until the angle of attack is somewhere between -2 and -4 degrees. Since on trainers they are often mounted with slightly positive incidence, these means that to fly inverted, you have to have more than 4 degrees nose up to create lift and significant speed.
