RCU Forums - View Single Post - Continued Battery Life Problems
Old 03-29-2010 | 01:42 AM
gene737
Default RE: Continued Battery Life Problems
Before you go nuts, try a lower charge rate. Charge those 2200 ma. packs at 200 ma. or less overnight. It sounds like your charger is kicking off way too soon. If you got a full charge into that pack at 1 amp rate, that pack should be warm to the touch. Nimh packs should be charged at 1/10 C or less. Good luck.
